Typical Holley problem , but I normally see it on older carbs . The throttle shafts have "sleeve" seals and a groove about 1/8" wide machined in the shafts to accommodate the seals ( strips of a nylon material ) . The main cause of this is side load over years of operation . Replacing them can be done , but is a pain as you have to remove the butterflies and throttle shaft to do it . Specialty carb shops can also put bushings in if it really becomes a problem .
This normally only shows up when the engine is off and generally overnight . My thought is that the carbs normally operate with a low pressure across that area , so any fuel leakage goes back into the carb . It also can give you a sneak path for an air leak and drive you crazy trying to find it .
Bob
