Old 05-21-2010, 02:15 AM
PANAVIA's Avatar
PANAVIA PANAVIA is offline
Originally Posted by Bartruff1 View Post
Panavia, I have a 351 Ford Racing Winsor...385hp....that is serviced at the local Ford (Roush) dealership and if I understand the reciept...they use 12 quarts of 20-50 Castrol ($7.78) and a Ford FL-1-HP ($18.67)..the car has been serviced there since new (2008) and now has about 6K miles on it...The car will never see a track and is not driven in anger .. the oil temps will approach 110 for short periods(minutes) of low speed high rpm (5000+) use....until I scare myself...the oil pressure is always around 40-50 and I don't see any leaks under the hood or on the garage floor. Since the oil is only changed every 3000 miles cost is not really a concern..but I don't want to spend money for something I don't need.. ps.. It will use a quart or even 2 between changes...bart
That sounds like too much oil to me for that setup, and the oil sounds a bit too thick , that oil temp also sounds high, and are you saying you are cruising at 5000?
Should be about 9.5 to 10 qts depending on pan.
With 6000 miles on the clock you should be down to 1 qt per 1000 miles on the ford racing windsors , hopefully less.
Have you done a static and leak-down compression on your cylinders ?
Steve
