Thread: No spark
Old 06-08-2010, 08:49 PM
FWB's Avatar
FWB FWB is offline
the distributor gear pin sheared off or the gear is wiped out. if the pin sheared it is due to the oil pump seizing from picking up debris.
pull the distributor see what failed, try to spin the oil pump shaft, if you can't spin it with a socket then its oil pump time....
