Old 08-14-2010, 05:56 PM
madmaxx madmaxx is offline
Easy to test gauge. Remove sending unit carefully. Boil pan of water. Place sending unit in pan, compare pan temp thermometer with gauge.
I found mine to be withing .5 degrees accurate. That is the best way to fill the cooling system with the temp sending unit slightly loose to bleed air, then tighten.
