Old 08-19-2010, 10:21 AM
azfordman's Avatar
azfordman azfordman is offline
Cobra Make, Engine: CCX-3-3624, 351w, 5-speed
First thing I tried was a new fuel filter....did not help.
After it dies there is "zero" fuel at the carb when I pump it manually...bone dry.
When it dies and I try to restart it does not try to fire at all....just cranks.
I know it is fuel related (not spark) because after it dies if I crank it and spray carb cleaner down it's throat it fires right up...and will continue to run for a few miles.
A float sticking from the heat is something I had not considered....thanks patrickt...maybe I will start by pulling the Holley off of my Bronco and see if that solves the problem.
"Freedom is only an illusion when the government has all the guns."
