Old 09-05-2010, 05:21 PM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
For your cooling fan needs go back to this thread here on CC, (the Lincoln or Taurus fans) http://clubcobra.com/forums/showthre...647#post963647
These 2 speed fans are complete with a shroud and easy to mount not to mention they are like 60 bucks at a wrecking yard. They do KICK A$$ but you will need to install proper wiring because they pull 28 amps on high!!
Sounds like you might have a wiring issue that is under suppling amperage and burning up your earlier fans .??
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
