Old 10-25-2010, 05:21 AM
mkassab's Avatar
mkassab mkassab is offline
Cobra Make, Engine: Unique 427 S/C, 427ci
Before you can get the outer glass really "clean", you must remove the road film that most cleaners will not take off. Us a wet towel and "Bon Ami" cleanser, scrub hard and then rinse with cool water. THEN use whatever glass cleaner you like.
Also proper prep for Rain-X or Aquapel.
One item I use to really clean road film, along with good soap is #0000 steel wool. I got this tip a while back.... works great!!
For final clean, micro fiber with Sprayway and Stoner. Each will clean a different film. Then, just keep up with it.
BTW, the 4 ZERO's (not 3, or 2, etc.... ONLY 0000) on the steel wool !!! It will not scratch the class.
Mark
Unique 427 S/C, B2 Motorsports 427ci SBF, TKO600, Jag IRS 3.73 Posi, Avon Tires.... and so much more http://www.uniquecobra.com/forums/forumdisplay.php?f=68
