Old 11-12-2010, 08:58 PM
madmaxx madmaxx is offline
So the nut was not on the stud, where was it? Is it in the oil pan? I guess it could not hurt anything, it would never get past the oil pump pick up screen, probably to big to go down the drain holes. I would just make sure it not hanging around somewhere.
I suggest checking the torque on the remaining ones, might want to torque the intake manifold bolts, as far as the rods and crank i would not bother unless you need to remove the oil pan to look for the nut
Originally Posted by N2VENOM View Post
The nut was found off the stud when I removed the valve cover. The nut came OFF! This is my 10th cobra and I have never had a problem like this. Parts are on the way. Darren
