Thread: 302 or 351 W ?
Old 11-16-2010, 08:24 AM
redmt redmt is offline
If you were racing at Bristol, then I would probably opt for the 2.750" mains.
But for 99% of the Cobra applications out there, a Windsor block is more than adequate....even up to 7000 rpm and higher. There are plenty of 393 and 408 Windsors that will spin to the moon.
400hp out of a 351W is basically just a good intake, cam, and carb swap. You don't need to rev the thing over 5000-5500 to get that kind of power.
A 351W EFI engine is a good choice as it's already set up for a roller cam. Throw a bigger stick in it, a carbed intake and carb, non-TFI distributor, freshen the gaskets and rear main seal up, and call it a day.
I like your way of thinking. I've found that you can build a more reliable engine with reliable horsepower if you stay withing what your requirements really are. I don't need balls out horsepower for a lite little car. If I was to go nuts with power , I'd base a motor on the 428 I have laying around.
John
