Thread: Jag Diff Noise
Old 12-05-2010, 09:47 PM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
Have you checked the tail shaft.....if you keep changing diffs and your not fixing the problem isn't it telling you that maybe something else is causing it....you said in your initial statement that the front pinion was loose thought it may have been incorrect bearing.... the reason it was loose is because the tailshaft is hammering the hell out of the pinion...
