Old 12-17-2010, 06:08 PM
David Kirkham's Avatar
David Kirkham David Kirkham is offline
Original Shelby Owner
Differential with axle housings and bearings.
This differential case had the inner pinion bore machined over sized. If you want to bore it out and sleeve it you can save a very expensive case. The differential unit is a 19 spline Auburn. The axle housings are copies of the original with the taper roller bearings. You will have to clean or replace the bearings.
Differential case $2000
Side axle housing with bearings $300 x 2 for $600
Auburn Differential $300
Retail $2900
Today $750
