Old 12-18-2010, 08:21 PM
patrickt patrickt is offline
Of course you are taking the readings right off the battery poles and not from the cable clamps, right? Bad connections are the first suspect. No chance of a slipping serpentine, right? That's the second culprit with an intermittent charge light. Assuming you want to do a parasitic check, I PDFed the pages from my GM service manuals. You can download them here: http://208.255.159.239/drain.pdf but here's a snap of the critical calculation for current draw depending on your battery specs:
