Old 12-22-2010, 05:26 PM
ERA Chas ERA Chas is offline
The voltage increases as the temp goes down, but the capacity decreases. Here's another chart that shows the fully charged voltage ratings for 12v batteries at various temperatures. It increases as the temperature declines. http://www.powerstream.com/SLA.htm
Copied from your link:
While charging, a lower temperature will increase battery voltage. Full-charge voltage on a 12-volt battery is 0.9 volts higher at 32°F than at 70°F. While discharging, a higher temperature will increase battery voltage.
Emphasis is mine. As Ronbo says also, those are while charging and discharging.
But thanks to all for clarifying.
Chas.
