Wayne,
I run an electric water pump too and control the pump rate using a thermo-sensitive switch which restricts the voltage to the pump and has the same practical effect as a mechanical water pump. My fan is also controlled by another thermo-sensitive switch so that I can dial in different temperatures for each unit.
This system automates the heating/cooling process regardless of season.
Cheers,Dave
