Old 05-15-2011, 10:33 PM
lal Naja's Avatar
lal Naja lal Naja is offline
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Originally Posted by jbcobra67 View Post
Sorry for the delay. When fully compressed it does still have a little force but I don't think its enough to cause a problem. The brackets I made are long and have 4 screws each on the hood, I thought this should spread the force out and prevent cracking, so far so good.
Thanks
Joey
I know that there are gas springs made, that when fully compressed, exert zero pressure. I became aware of these zero pressure gas springs years ago from a client of mine that produced gas springs. Company was Suspa, in Grand Rapids, Michigan.
When I have some timeI will track down these Zero pressure gas springs. But if anyone comes across these please post your findings.
I've read a couple of posts about gelcoat cracks appearing in the area where the hinge mounting points are glassed to the body. So adding a 15 or 30 PSI constant load to these points concerns me.
Thanks,
Arthur
