Old 07-12-2011, 07:21 AM
392cobra's Avatar
392cobra 392cobra is offline
6th Generation Texan
Originally Posted by wedgerton View Post
I talked directly to the folks who built the Carb and they said they go on the rear to stop the gas from sloshing up against the jets when you hard brake. If you think about it, the gas will go forward in the bowl when you brake and in the front the gas would flow away from the jets where as in the rear it would flow up against the jet. He said the flow up against the rear jets causes a vacum of sort which draws fuel into the carb thus flooding it.
I feel comfortable this will fix my problem.
Wayne E
Then how come the engine doesn't go rich or flood when you accelerate hard and the gas flows up against the primary jets ??
