Old 07-31-2011, 03:20 AM
Default If one is crack-----
tom meyers Tom not to be the bad guy here BUT, if one is broken the rest are not to far behind with the same problem. There are some other companies you should look at like H&Sharp rockers. Try to find a set of ERSON. They re bolt on and the best bang for the buck. Been racing them for 6 years and no failures unlike ----. If money is no problem the heads will need some work, Jesel or T&D. I think T&D have a bolt on kit. Check with Brent B. Keith Craft, or Barry R. at Survivalmotorsports They will all give you the best price. Hang the Doves on the wall. Yes a ran them for 3 years and broke 2 shafts. One was there standard one and the other was a heavy duty one. Both broke at the bolt hole between #7 and #8 cylinders. The heads where check and flat at the mounting points. 6,200 rpm limit on this motor. NO reason for this. I do have a set but with the problems I had with shafts and working the oiling for them wouldn't sell or give them to a friend or enemy. Rick L.
