Old 09-05-2011, 08:58 PM
nymathboy nymathboy is offline
Originally Posted by Dwight View Post
Accel's installation instructions suggest you mount their oil filled coil vertical. They do not tell you if you mount it horizontal or on a non vertical position the air bubble inside will expose the coil and burn it up. If you call and ask them about it they will tell you it "should" be mounted vertical or it will damage the coil.
Did you have an oil fill Accel coil?
Dwight
I believe that is was mounted at a 60 to 70 degrees angled upward position. It was not 90 degrees vertical but far from horizontal
It was oil fill.
In anycase I will update on how long the duralast coil lasts. It is mounted in the same position.
NRA member
