Old 01-29-2012, 06:21 AM
wrench87 wrench87 is offline
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
ok if you run a spacer they reccomend the 4 hole type where would you put the nipple? would it go in one of the rear holes or would you have to install it in the middle so it uses both holes?. i think they make a aluminum one but wouldnt that defeat the purpose for heat soak, i would think the composite would be best?.
