Old 02-21-2012, 02:13 PM
jolsen42's Avatar
jolsen42 jolsen42 is offline
Hey Pat, thanks for the kind words. Yes I did use pin drive LCA's and still had to move the mounting point in even further. I also had to move the upper shock mounting Hole in and also do a hatchet job on the upper arm. The wire wheels I purchased from Dayton Wire Wheels And yes it is a Fox rear, narrowed.
Regards,
John O
Originally Posted by ICBomber90 View Post
John,
Awesome Re-re-re-build! Just a few questions....
Did you change out to pin drive width LCA's? Is the rear-end standard Fox? Where did you source your wire wheels?
Thanks,
Pat
jjo42
