Old 08-05-2012, 05:01 AM
Default Do you have any pictures?
dls 141. If you have the steering shaft unhook and the 2 mounting supports the whole unit should drop down and you should be able to slide it out of the dash. If you could get a could of pictures of the problem we might be able to walk you through it. You are trying to remove the steering column and not the steering wheel or hub? This should be more than a 2-3 hour job if you have all the parts. Rick L.
