Old 08-13-2012, 10:17 AM
Mongoose930's Avatar
Mongoose930 Mongoose930 is offline
Cobra Make, Engine: Hi-Tech
Per the MSD Tech Line for the Blaster 2 Coil:
The primary resistance, measured from the coil pos. stud and the coil neg. stud should be .7 Ohms. That is 7/10 of an ohm +/- 10%.
The secondary of the coil measured between coil pos. stud and the center tower (where the coil wire clips on) would read 4.7K Ohms. That is 4.7 thousand ohms (4,700 ohms) +/- 10 %.
