Old 08-20-2012, 08:19 AM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
The clutch plate/disc does not get balanced with the assembly. If I was you, I would get the short block, take the crank out , at least ,( you should do the pistons too), and find a balance shop. There has to be one somewhere. Broken cranks, cracked bell housings, are all a result of out of balance. Do it right once or continue paying...............its an easy choice really!!
