Old 10-13-2012, 06:31 PM
DanEC's Avatar
DanEC DanEC is offline
Nose is jacked up in the air. Hose on the bleeder nipple buried in a jar of brake fluid. Couple loose connections at the start but after tightening them up the system was tight. Most of my cars have had manual clutch linkages - but guys, I've been bleeding brake systems for at least 25 years. I agree - something is wrong.
Are you vacuum bleeding or pressure bleeding from the slave bleeder? Are you leaving the pushrod to the clutch fork in?
