Old 10-14-2012, 05:26 AM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by Jaydee View Post
Is the piston in the master cylinder bottoming out on the circlip. If not, then the port to the reservoir will be blocked by the cup. Occasionally, if the cup has swelled for any reason, it will also block the port.
JD
I am getting fluid through the system so I tend to think I don't have this problem. Thinking back I think the cylinder of the slave was rotated where the bleeder was not on top - I'll see when I get back to it today. Also I think trying to bleed it by stroking the slave from the shaft arm instead of the pedal is working against me.
