Old 10-22-2012, 01:59 PM
ERA Chas ERA Chas is offline
Lou, just tune that goofball Chas out -- RodKnock too. If I had a nickel for every time they pissed over a serious thread..., ahh nevermind.
If that does the trick then there are easy ways to make your heat soak problem go away. Unfortunately, those tricks will not work on Chas.
OK I'm done here. Lou-don't fear- I will never sully your posts again with an attempt to help you. In doing so, I apparently offended your sensibilities-probably because you can't comprehend the analogy I used. It was clear common sense but you couldn't see past what you didn't understand.
Are you related to a guy named 'Rsimoes'?
Unlike about 14,000 other members, I did post a serious attempt to help you and a photo too. You still don't get that. Won't happen again.
Counselor-your version of good cop / bad cop? First you scam the guy, then you 'help' him. As Bogie once said, "You're good."
Resume holding hands.
Chas.
