Old 02-23-2013, 08:57 AM
DanEC's Avatar
DanEC DanEC is offline
Default Bob - problem solved
I checked all the wires through the 54/27 connection but failed to register there are two green wires running through there. I had checked that on the wiring diagram but I think the only other green wire that was shown was supposed to have a black stripe. I ran a long piece of wire back from the turn signal and started running continuity checks at the plug and sure enough the green wire at the turn signal location on the plug was dead. So I started stabbing all the other wires in the plug and got one that gave me a buzzer - turned the plug around and this wire was solid green too. They were just switched. I hadn't noticed anything else not working - I guess I need to see where that other green wire goes to. But all is well.
Have a good weekend.
