  #29 (permalink)
Old 03-13-2013, 08:52 AM
lippy lippy is offline
Originally Posted by gsharapa View Post
On my 6th Cobra and 4 were small blocks with 2 solid rollers and 2 big blocks both solid rollers. My current Cobra is KC 496 FE, Pond aluminum block, 10.7 compression, with solid roller, T&D shaft mounted rockers, single plane intake (cut down 1/2 inch), Quickfuel 850, Edlebrock stage 3 aluminum heads and aluminum flywheel. I love it as it knocks down tork at the low end an moves the tork & HP up in the higher band. Spins like a small block and idles at 900 rpm. It made 681 at the crank. It drives great and of course has the HP if you want it....
Originally Posted by PLDRIVE View Post
Lippy, lets see if Brent will give U a 30000 mile warranty on the lifters.
I'll need to contact him in 15 years if they fail at 30k
