Old 03-23-2013, 05:07 AM
A98Coupe's Avatar
A98Coupe A98Coupe is offline
Cobra Make, Engine: #535 Kirkham 427, 427 Side Oiler
Default SW Installation Instructions
Paul,
No problem, but I can't attach to this post because the file size appears to be too big. I'll e-mail the files to you.
Also, I would recommend that you replace the seals, gaskets & diaphram if you haven't already done so. If the rubber diaphram on top of the pump has perished, you will quickly have a trunk full of fuel!
I know someone in the UK who was supplying SW 240 rebuild kits, but will need to dig out his details if you are interested.
Regards
Stuart
