Originally Posted by DAVID GAGNARD
I'm looking at my last dyno session and all the pulls started at 3500 rpms.....That part I understand,looking the water temp,it stayed between 145 and 150......
looking at your dyno sheet,your water temp was in the 138 to 145 range,any particular reason for these water temps vs. running the water temp at 180 degrees,more closely to the "normal" operating water temp.???
Just curious.....
David
I normally run the pulls at around 160 water and
oil. Its really a habit from the EMC rulebook, where the 160s are the required minimums and I set the thermostat on the cooling tower to that level. The water cools pretty fast when the engine's off - I have 1500 gallons in a vertical tank behind the back wall. Normally I'll run it for a while under moderate loads to build temp. On this particular pull I was re-lighting it after checking valve adjustments & plugs and realized that I was getting darn low on gas - so I just smacked it as soon as I felt comfortable enough. I happened to have it nearby to scan 'cuz it was the last one of the evening...
Brett can confirm seeing some Hollywood numbers on some sites where water was at 110 or less...
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
