Originally Posted by vector1
I have found AN fittings between brands can use different size wrenches when fitting hose. The AN size though should fit the coupling nut, I would guess some better than others. IMO the only benefit to AN wrenches are the different angles that can be used if the wrench is designed in that fashion, otherwise a good quality wrench should work fine and not scratch the finish.
I have the XRP set of wrenches, but then bought a set of double-ends from Gorilla Tools and that's all I use now. The angles of the wrenches have been invaluable and I couldn't have done some of the contortionist work without them.
