Old 07-04-2013, 05:03 PM
stephen low's Avatar
stephen low stephen low is offline
Jim
That's right but I've already gone smaller on the master from 3/4 to 5/8th and this decreased my pedal pressure immensely but still not enough.
Increasing the slave to 7/8th from 3/4 will also have the same sort of effect and will further reduce the pedal stiffness.
But I am going to have to check whether I have sufficient fork stroke now to permit some further reduction in this travel if I do change the slave.
Current pedal ratio is 4:1, if I move the contact hole up some 10mm as has been suggested the ratio moves up to 5.2:1. This too would soften the pedal pressure feel.
It's a bit of suck and see now as to which option might get me a good result and I'm likely to check out both ideas.
slowy
