Old 07-30-2013, 09:12 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Excellent. Should the problem return. I would remove the heat shrink tubing on the two wires connecting to the AMP meter and check the crimps on the metal connectors to the wires. Since you jiggled them, you may have temporarily re-established contact between a bad wire and its female connector end. You can easily replace the shrink tubing on the wire and connector....
But you are most likely ok....
Blas
SPFWiringDiagrams@Comcast.net
