Old 09-30-2013, 02:57 PM
lippy lippy is offline
Cliff,
Why nervous? You did a ton of sophisticated work on chassis-I assume you have lots of track experience.
All Brent's engines have a throttle-you should only use what you're comfortable with.
You could add a throttle stop (as I did) easily to limit WOT until you're comfortable-in my case, to prevent over-centering the linkage.
What did you use as a throttle stop? Sounds like a good idea to get used to the car.
