Old 10-11-2013, 11:25 PM
Rare Iron's Avatar
Rare Iron Rare Iron is offline
Originally Posted by CHANMADD View Post
If the little louvres face forward...(the opening facing airflow) .....it will be quieter and use some horsepower....if they face back ..its louder but less power loss....
If you go with the 3" core, the small louvers will not rob much HP at all, same with the 2.5" versions. The 2.5" versions are significantly quieter. If you go OVER the louvers vs. into them, loudness will go up approx. 4 dBA's.
QUOTE: The thing that finally tilted me towards the SS muffs over the Cobra Packs is that the SS mufflers are a perforated core design so I didn't have to struggle with which way the louvers should go.
Keep in mind, different types of perforations will produce different sound as well, so will the type of packing used. I've also had numerous customers tell me that 304SS pipes will create a "ring" to the exhaust note. Annoying to some, but not to others. I can't build mine out of stainless - heavy 16 ga. aluminized only.
COBRAPACK Mufflers
www.classicchambered.com
