Old 10-14-2013, 09:46 AM
ERA Chas ERA Chas is offline
Originally Posted by MOTORHEAD View Post
ERAChas:The intake gaskets I used are BT double thick from Barry R. Due to head milling and used manifold with unknown prior machine work I had too much gap with ports lined up for std thickness 1247 gasket, plus trimming it got into the printoseal mat'l. (My ports are 1.5x2.4) The BT gasket is for the large gap between intake and head and has extra mat'l for the lg ports. Don't know if the 1247S3 is thick enough.
Thanks for the valve seal info, I'll have to get some.
Now I understand. I might just try doubling the 1247S-3's if you check the thickness compared to the BT's you have. If they size right, I might trim the port into the printo seal area and seal that area with Motorcraft gray RTV. I'd call call Barry first to ask if that works as those gaskets are definitely the solution to sealing the ports and water.
Chas.
