Old 01-12-2014, 04:43 PM
blykins blykins is offline
Originally Posted by Ant View Post
Thats really good information which answers my question.
This engine has a main bearing bore of 2.250" clearance of 0.00275"
Rod Journals bearing bore is 2.001 with clearance of 0.002"
I guess that gives me on the mains approx 0.0035" when hot which would indicate at least a 40wt oil. I assume if you wanted to use a really thin oil for less friction and more hp you could go to an oversize bearing shells and reduce clearance.....
Way, way, way too much clearance for a 302 sized main. I set bearing clearance at .0015 on aluminum 302 blocks. With .0035 clearance you will have a considerable oil bleed there, which can cause cavitation and other issues. I don't even run .0035 on windsors and 460's.
If you have the engine apart, I would put some .001 bearings in it at least.
Rods are right on the money...
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
