Thread: shocks
Old 04-11-2014, 10:43 PM
Double Venom's Avatar
Double Venom Double Venom is offline
I know it's good hard and earned money but Bob is so right . A good QA-1 shock like the DS-01 shock with 250 lb springs for the rears, and you will never have to worry about replacing them again.
The shocks have a very simple 7 way adjustment to them and can be changed in seconds with no tools needed.
And you won't need the "bump" stops on the rear! You do however still need to use the stop that should have been bolted on the frame to keep the rear axle from hitting.
DV
