Thread: Carb Diagnosis
Old 06-25-2014, 07:33 PM
Wbulk's Avatar
Wbulk Wbulk is offline
Cobra Make, Engine: 66 Cobra
jhirasak, well thought out and articulate, and reasonably plausible. However that is not the cause of this issue. Perhaps I should have mentioned I have two power valves and tried them both. I also tested the diaphragms of both with my Mighty Vac which I have a special cup just for testing power valves. I also questioned Quick Fuel if they ever had one where the needle was not seating. This is hard to test. They said they had just one.
I want to give clues, but then this would be over too soon. Remember you must be dead on with the issue.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
