Old 10-19-2014, 02:43 PM
aa909's Avatar
aa909 aa909 is offline
Originally Posted by eedeutsch View Post
Mine also rattles when I am going slow. It probably rattles all the time, you just can not hear it going at some speed. I was told that the baffle is a straight through fiberglass pipe with holes in it. It sits in the side pipe loose. That the rattle is normal. I really do not know for sure.
I looked inside the pipes with a small light and you're right, it's straight through with perforated baffles. I couldn't see all the way through and not sure if they are sitting loose or not, but they aren't "packed" like before.
In any case the only way to stop the can-of-bolts at slow speed is to go into neutral.
Thanks
Art
