  #30 (permalink)
Old 01-19-2015, 10:28 AM
patrickt patrickt is offline
Originally Posted by davids2toys View Post
Well it came and it turned out to be a spray can...UGH. I specifically told them I did not want an aerosol. I actually sprayed a little into a cup to see if the consistency would stiffen as it was exposed to air. No it did not, pretty loose and I could wipe it off with a cloth pretty easily. It had the consistency of some moly grease I have in a tube. I am giving this back and I might use the moly grease I already have.
What do you think Patrick?
I wouldn't use it. Go with the moly grease that you have, and if you find that you have leaks around the gaskets and covers that drive you nuts, then we'll go on a hunt for the good stuff.
