Old 01-26-2015, 02:28 PM
DanEC's Avatar
DanEC DanEC is offline
I pulled #6 fuse killing the parking lights. When I turned the turn signals on all 4 corners and license plate light flashed including the parking light led units in the tail lights. Turn the parking light switch on for the heck of it and there isn't any change.
Reinstalled #6 fuse and pulled one fast blow TR fuse. Key on and turn signal on - all 4 corners flash with the one TS direction. In the other direction only the front light flashes and the rear are all dark. License plate light also flashes so turn signal circuit is energized.
Pulled #6 fuse and one TR fast blow fuse, key on, parking lights off, turn signal on - all four corners flash including the parking light led units as well as the flasher ones. Flipped parking light switch on but no different.
Forgot to check with #6 fuse out but I tuned off the parking lights and turned on the turn signals and the panel lights do blink with the lights. I hadn't noticed before as I had the adjustment turned to off.
Grounds still hooked up from lights to battery.
ERA 782 Running
