Old 10-26-2015, 09:53 PM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
Since it's not original, it must be a replica. Only the original can be genuine or authentic. Anything built later will clone or replicate the original. You can call it a genuine replica or true replica, if you must, but it's an oxymoron.
Maybe if you would expand your vocabulary a little bit. Add Continuation to it.
The VIN sequence is meaningless, since even CSBI will producing the "competition" ("Resurrection") replicas with leftover CSX3000 numbers. These are replicas as well and the sequence will follow the original CSX3000 series cars. Also, modern cars use 17-digit VIN #'s, which weren't used in the mid-1960's.
So, how about those Jaguars? Go ahead, try to convince Jag that they are making "replicas". If it works here, it has to work there too.
Further the Shelby replica uses different components. So it's not an exact replica....
So how about those Jaguars?
Tony
CSX4005LA
