  #27 (permalink)
Old 03-06-2016, 11:27 AM
steve meltzer steve meltzer is offline
Club Cobra Member
Cobra Make, Engine: Kirkham/Southern 427 SO finally on the road
My 4-speed toploader also pops of out gear as described by the OP, but now I can't even get it into 3rd or 4th. (Reverse and 1/2 are OK). The linkage is perfectly aligned/indexed. When I removed the bolt (see picture). The bolt takes a 9/16 wrench, but its diameter is 3/8, I think. At any rate, i removed this bolt, but there was no spring and now I'm not sure if I just need to adjust it, or, the spring is ??? Any thoughts here? Maybe the gearbox is really toast, but if I can fix the car without foolin' with a rebuilding of the toploader, that would be a good thing! The car only has about 2K miles on this Southern-built box. No hard miles, no track. thanx steve
steve meltzer
"I may be wrong, but I'm never in doubt"
