Old 05-20-2016, 02:24 PM
K1w1 K1w1 is offline
Thanks Guys, sorted
Just a heads up, if you're ever changing a water pump from LH to RH, make sure you have the timing cover without the hall sensor, alternatively the sensor mounting can be hacksawed off insitu, in 5mins and then dressed so it is hardly noticeable.
Install a 2 o'çlock timing pointer, transfer the timing marks over and then install the pump
New length bolts are required for the pump
New alternator bracket mounting bushes will be required
Rob
