Old 06-08-2016, 02:10 PM
Ace23 Ace23 is offline
Cobra Make, Engine: SPF#1867 , KC427
The springs are the same across the SPF line however you could go higher on rate if needed, we can supply alternate rates coils. Remember that you have "coil overs" and the ride height is easily adjusted if required.
I may have a set of the 385 headers in stock.
Mark,
The spring rate may require an upgrade with the additional weight....maybe not just have to try it and see. What size diameter are the 385 headers? Cylinder head selection would impact the header selection......are the headers you have designed around the cobra jet heads?
