Old 07-21-2017, 08:31 AM
Speedwaypj Speedwaypj is offline
Cobra Make, Engine: A&C (near future)-460
Default Thanks again - update.
Appreciate the input from all!
I replaced head gasket, and intakes...noticed old intake gaskets had center water port closed off for manifold. Replacement intake gasket has it opened. Should help. I built a shroud that covers about 2/3 of radiator. (I'm running 6 blade flex fan). Still seems to get hot while idling(235 F). If I use aux garage fan it goes down to 210 F. So, I guess I'll find out when I have permanent shroud....and if needed I'll add elec fan.......... The reason that I am running a mechanical fan is to move more air through the engine compartment to try to relieve the inherent heat of a Cobra. (Timing is at 16 BTDC)
