Old 08-29-2017, 05:57 AM
xb-60's Avatar
xb-60 xb-60 is offline
Originally Posted by muzzza View Post
Going in from RH side.......Raise rear of diff as high as possible - slide it back / rotate diff to get it back as far as you can ( not easy, still holding the diff up !! )........then nose of diff should swing across into place easily. Had mine in and out quite a few times.
Thanks Muzz. Do I need to keep the rear up high as I swing it around 90 degrees?
Will be at it again tomorrow.
Glen
