Old 12-27-2017, 07:45 PM
2bars 2bars is offline
Cobra Make, Engine: Superformance, 427 FE
Originally Posted by twobjshelbys View Post
I chose a CSX for that precise reason! I sat in both and the steering wheel on the SPF hit me in the lap.
Bottom line and the advice I give everyone is that you SHALL NOT buy any Cobra until you sit in THAT CAR! This is especially true if you are looking at models that are more than a few years older than one that you test fit. SPF made several changes as the generations progressed so fitting in a newer one won't necessarily mean you'll fit in an older one. Same for early CSX vs later ones. Just try it on.
Note that CSX come with defroster/heater too. (At least mine did) It's required! Don't get one without it. First time I was in a little bit of rain the windshield fogged up. (The wind kept the rain out, until I happened to hit a stop light!)
Yes, go try them on. And like you said here, different years may also be different.
I can tell you that if I would have fit better or the same in the CSX, I would have bought it.
If enough people disagree with me, I know I am doing it right
