Old 02-22-2018, 07:32 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
If you purchase a cheap knock-off rubber boot, you will find that it will develop a whiteish grey chalkie finish on it after being exposed to the sun and the UV rays for a while. They also tend to be a bit thicker and contribute to the shifter popping out of gear occasionally..... a taller boot just adds more stress to the boot because of more boot material is moving around when you shift so it cracks sooner.
Blas
Note: A good time to check and tighten all your grounding points under the dash and in front and back while sitting in the front seat as the boot replacement is a quick project, and your in a working mode....
Blas
SPFWiringDiagrams@Comcast.net
